![]() | Home > Technical > Slight misfire |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 748 ![]() ![]() ![]() |
You timing chain guides may be worn and allow for some chain slack on idle. Regards etc.,
Nothing to indicate that to be honest |
The simultaneous lean and misfire codes happening no matter if you run LPG or petrol, may indicate an issue with the timing chain (guides and/or bent bolts that fit the guides to the engine block). Seen this on two vehicles. A sure indicator of this issue would be increased rattling noise coming from the front of the engine at idle, disappearing on slightest push of the accelerator pedal.
Hi I don't get the codes on petrol so I know that's just a gas thing and there is no noise on start up when cold or warm it does sound sweet I am going down the electrical route dirat as I said in my previous post it is not consistent so I would have thought if I had valve wear it would be there all of the time which it is not |
Yupp, that changes everything. Good luck! Regards etc.,
