Home > Maintenance & Modifications > Are After - market Timing Belt kits ok ??
keithdub1973
Ireland 2008 Range Rover Sport TDV6 SE Java Black
hello chaps,
long story short , I've been a silly sausage and bought a 2008 L320 with no service history ! yeah i know ... Rolling Eyes
there is nothing marked in the engine bay to say that the timing belt was done at any stage...
there is 200k on the clock and I will definitely have to get the belt done ASAP .
A few questions..
1. is there a decent after market kit that anybody could recommend ? .
2. is doing the rear belt a must ?
3. should i definitely get the oil pump changed at the same time ?
4. apart from having my head examined , is there anything else i should look to check or replace ?
thanks in advance.
Post #524845 Sat Apr 29 2017 5:20pm
1. Dayco belt kits are good
2. At 200K I think you may as well. Apparently they can slice thru the wiring loom if they break up
3. At 200K yes
4 replace alternator belt
Post #524854 Sat Apr 29 2017 5:54pm
keithdub1973
Cheers Andy , I presume ebay is as good as anywhere to pick up the kit and pump ?
Post #524855 Sat Apr 29 2017 6:01pm
SRE
Spain
Expensive engine if the belts fail, so why try to penny pinch on cheap belts ??? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #524857 Sat Apr 29 2017 6:04pm
geoffsnook
Nothing wrong really with dayco belts i think there made by goodyear Thumbs Up
Post #524858 Sat Apr 29 2017 6:22pm
Yeap some good suppliers on eBay.
Look out for a locking kit supplied too
Buy a Citroen pump as they are cheaper
Post #524861 Sat Apr 29 2017 7:04pm
Disco_Mikey
Dayco belts are OEM
Yes, do the rear belt
Yes, do the oil pump
Do the idler pulleys for the front belt, as well as the aux belt. Be prepared to need an aux belt tensioner
Post #524878 Sat Apr 29 2017 10:12pm
