![]() | Home > General > Anti Roll Bar Leak? |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
I can't see any pictures on the thread, as far as I know the ARB would not affect how the car sits when parked up, in respect of the leak have you checked the reservoir behind drivers headlight to see if fluid has dropped. Nanocom Evo |
hiflyer81 Member Since: 09 May 2014 Location: High Peak, Cheshire Posts: 13 ![]() ![]() ![]() |
It's added them to the gallery by the look of it. It's the 4 photos along the top.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
That's a split CV joint boot not your roll bar.. |
Ok, is that expensive? Or is it just the rubber boot? Where is all the oil coming from?!
The CV joint is part of the drive shaft (this transfers power to the wheel), the joint is full of a thick grease that's held in by the rubber boot. Because your boot is split and the shaft spins it has thrown grease in a circle round the drive shaft. So while it looks like oil it's not.
THanks very much for this. I was thinking I'd got a horrendous bill coming up with the MOT Being on 6th May! May keep the car now instead of quickly disposing of it.
