Home > Maintenance & Modifications > Bolts on rear prop, replace ?
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
I'm changing the rear prop on my RRS. Should I replace the bolts into the transfer box and rear diff at the same time, or it safe to re-use them ?
Thanks awfully !
Post #523029 Thu Apr 06 2017 5:54pm
I re-used the prop bolts
Post #523030 Thu Apr 06 2017 6:02pm
Black Bess
Yep, should be okay to re-use.
Post #523264 Tue Apr 11 2017 10:49am
Here's what the workshop manual says:
http://www.rrsport.co.uk/gallery/albums/us...eshaft.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #523343 Tue Apr 11 2017 9:03pm
Black Bess
It does sound as though the flange with the 4 bolts, with a torque setting of 110 lbft may be using stretch bolts. It would be best to replace those, or at least ask if they are stretch bolts. The other end should be fine to re-use.
Post #523390 Wed Apr 12 2017 9:25am
CornishRob
OK, thanks.
Well put the new one on this morning. Took about 2.5 hours, but a lot of that was me phaffing about putting the rear on the ramps, and slurping tea etc. You can get to the six bolts on the transfer box end quite easily, as there is plenty of room, but I had to shimmy the RRS forward a touch to get to one of the four bolts of the rear diff.
All rather satisfying, now that I've done it. Thumbs Up
Post #523629 Fri Apr 14 2017 5:24pm
Eaters
Well done. Sounds like a good job.
Can I ask what led you to deciding to replace the shaft? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #523633 Fri Apr 14 2017 6:15pm
CornishRob
It was in the local independent some time back for some other work, and he mentioned that the centre bearing was "on the way out". Since then I've had the classic low speed judder when applying power going up hill.
When I looked at the centre bearing, it was quite bad, so I'm surprised at how well it drove. Whistle
Post #523635 Fri Apr 14 2017 6:34pm
