![]() | Home > Technical > Few issues after once over |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5115 ![]() ![]() ![]() |
ignore:
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Suspension squeek at slow speeds is probably your ARB bushes, common fault on the RRS |
sestorious Member Since: 12 Apr 2013 Location: doncaster Posts: 91 ![]() ![]() ![]() |
Thanks guys ! Checked all bushes and they are solid so might lubricate them with silicone spray for the time being ?
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
My advice is you spray silicone lubricant on one bush at a time then test drive: that way you'll find out the culprit so you can check if its shot or just got dust ingrained. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9110 ![]() ![]() ![]() |
Loud squeak is possibly a rear hub bush. Rock the car and you'll hear which corner it is. When mine went they were pretty loud - pedestrians would look round when the bush squeaked! 2012 SDV6 - it's missing a couple of cylinders
Thanks for the reply ! It sounds like it's coming from the front but I'll try wat you said! |
