Home > Maintenance & Modifications > Turbo failure
Lonerangerv8
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
Turbo failure
Is I normal or possible for a turbo on a tdv8 to fail whilst the engine is just ticking over ?
Post #522298 Wed Mar 29 2017 9:38pm
Paddi
Oh dear - what happened?
Think there was at least one report - the infamous 'Simplesimon' event when a TDV8 lunched its engine shortly after start up and at low revs.
http://www.rrsport.co.uk/forum/topic29765....mple+simon
Sounded as if the oil supply system failed, the turbo oil seals blew and fed engine oil straight to the intake side causing a hydraulic lock.
Presumably this would have been blockage of the turbo oil return pipe with oil sludge and it may have been building up for some time. 2008 MY Java Black TDV8 HSE
Post #522327 Thu Mar 30 2017 12:05pm
Ian.H
Mine just blew both turbos a few weeks ago due to an oil seal letting go in O/S turbo and that ultimately led to the N/S one being starved of oxygen apparently. Had only driven 1/4 mile, coasted round a 1st exit off of a roundabout, went to accelerate and umm... nothing! Recovered, RAC tried to start it but just clicked (knackered starter sound).
End result, 2 turbos, new starter.. had brake pipes done whilst body off and a service and a few odds and sods..... £4.5k. Now at just over 90k miles.. but the rest of it still going strong.. should keep going now for a while... I hope! Smile
Cheers..
Ian
Post #525120 Tue May 02 2017 11:44pm
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
The other issue that can happen is the hose let's go and the turbo overspeeds killing it Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #525192 Wed May 03 2017 8:41pm
harbieboy
Turbo failure
Just suffered the same. Have replaced turbos (body off), replaced brake pipes and under sealed.
Car back together and engine runs fine. However mechanic tells me she is using oil and suspects the turbo failure has damaged a piston. He advises investigation at a cost of another 2-3 days of labour and then engine repair.
What to do?
Car is 2007 TDV8 in great condition and low mileage (80k) but this extra cost means I will have spent the current part exchange value:blub:
Any advice ? jaguar XKR 4.2S
Previously Jaguar XF
Disco 3
Mercedes E Type
Post #529561 Tue Jul 04 2017 5:03pm
I would want to know how he intends to repair it. LR don't sell bits for the TDV8 so a replacement piston comes from where? Broken TDV8s lead to new engines usually unless LR have changed their spares policy. 2012 SDV6 - it's missing a couple of cylinders
Post #529579 Tue Jul 04 2017 8:32pm
DrRob
Re: Turbo failure
What to do?
Any advice ?
Sell it? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #529581 Tue Jul 04 2017 8:41pm
Johnski
I would personally get rid, quite often Turbos going can do damage to the engine, generally more so, when it won't allow you to turn off.
Positive side, you know what's been done etc to car, but never purchase without a decent or LR warranty, this would have been covered. Big Cry John
Post #529591 Tue Jul 04 2017 11:03pm
