Home > Maintenance & Modifications > Engine Faults
Pufftmw
Engine Faults
So I got me an IID thingy as car is running sluggish, with no oomph when pressing the loud pedal and struggling to go up steep slopes on motorways etc.
Also seems to hold gear a bit longer and sometimes slow on change ups/down.
Anyway, got the below. Any ideas as to the issue? Turbo actuator is a possibility obviously
Engine TDV6
P2199-21 (6C) Intake air temperature 1/2 correlation - General signal failure - signal amplitude<minimum
P0114-27 (28 ) Intake air temperature sensor 1 - circuit intermittent/erratic - General signal failure - signal rate of change is above the threshold
Post #521513 Tue Mar 21 2017 10:30am
Disco_Mikey
Most likely a dead MAF, but very slight chance it could be a wiring issue to the MAF sensor Thumbs Up
Post #521514 Tue Mar 21 2017 11:05am
Pufftmw
Thumbs Up Thanks DM
New MAF ordered and also cleaner for the MAP sensor. Will see how we get on...
Post #521517 Tue Mar 21 2017 12:13pm
try to only change one thing at a time
Post #521528 Tue Mar 21 2017 1:17pm
Pufftmw
Good point, well made Smile
I will do the MAF, take if for a blast down A2 & see if that cures it. MAP clean is just for maintenance.
Post #521531 Tue Mar 21 2017 1:24pm
Pufftmw
New MAF arrived, fitted it in like 10 mins, cleared codes and tried to go for a blast down the A2, which was absolutely jammed & now under average speed cams. Anyway, lagged back a bit and booted it a few times, giving it large from low revs/high gear and it *seems* to be a lot more lively and responsive again. Bottom line is that there were no faults showing after my little jaunt, so fingers crossed its all back to normal again Thumbs Up
Will try & give it a little toot around the M25 tomorrow Smile
Post #521913 Sat Mar 25 2017 9:55pm
Pufftmw
Was going to do a "How To" for a MAF change but it was so simple...
MAF sits between air filter and big tube for intercooler.
Unplug the plug from the MAF, unscrew the jubilee clip between MAF and tube, unscrew the lid of the air filter and lift off.
There's one bolt that keeps the MAF firmly attached to the lid of the air filter, remove that, twist MAF towards you and pull away from filter housing.
That's it - just put the new MAF in and repeat the process in reverse.
Alternatively, if you're just cleaning the MAF, do so with specific MAF cleaner ensuring you never actually touch the MAF
Post #521914 Sat Mar 25 2017 10:06pm
Buckster
Glad its sorted mate, you have a PM Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #521915 Sat Mar 25 2017 10:21pm
Pufftmw
Thanks DM, good call. I was able to give it a more "spirited" drive up to Suffolk at the weekend. Hard acceleration going up long hills on M11 from 50 it wouldn't have managed before MAF change, no longer holding revs instead of changing under acceleration, tickover down etc.
Just checked IID and no faults Smile
Happy bunny again, just need to find out if I've got a front diff issue Shocked Big Cry Rolling Eyes
Post #522986 Wed Apr 05 2017 9:02pm
