Home > Technical > Mud and Ruts setting warning with towing electrics fitted
DrRob
I have 13 pin towing electrics fitted and they have been enabled by an independent specialist.
When I select "Mud and Ruts", I get a warning flash up saying "Trailer Connected" (or very similar).
Is this normal?
Any chance someone else with a MY12 and 13pin fitted check for me? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #518552 Wed Feb 22 2017 8:37am
SRE
Spain
DrRob
Just tried mine for you, "Mud and Ruts" no warnings except select low range.
However mine is a 2011 with 13 pin electrics fitted by main dealer. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #518565 Wed Feb 22 2017 11:15am
DrRob
Ta. Did it say "Low range not selected" or something similar? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #518594 Wed Feb 22 2017 2:26pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Dr Rob, I've just checked on my 2012 and the only message is advise select low range, I have 7 pin tow electrics fitted and coded by Bodsy. Is the coding incorrect or a fault with the connections?
Post #518603 Wed Feb 22 2017 3:26pm
DrRob
I've asked Guava to check it when it goes in for its service soon.... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #518624 Wed Feb 22 2017 7:06pm
Buckster
If im back from offshore before your service you can plug into mine and try it Rob. Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #518667 Thu Feb 23 2017 12:04am
DrRob
Engage Low Range
Select Mud and Ruts
Warning = "Trailer connected. Off road height not automatically activated"
Odd as no trailer connected! Whistle * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #518953 Sat Feb 25 2017 5:41pm
