Home > General > Quick Question about 2010-2013 Range Rover Sport AWD System
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Hey guys,
There is WAYYY Too much info out there on Land Rover and Range Rover's All wheel drive system.... All I'd like to know is if my model and year have a mechanical 50/50 split AWD system or a Haldex type system that is Front WD until rear or both is needed.
I tried YouTube, Google and got so many returns that I have not clue where to start and the reason I ask is because I found my old 2002 Audi A4 Quattro system to be pretty decent. It is a mechanical AWD with an even 50/50 split. I know that engaging Sport mode and other modes locks and unlocks the front or rear but there is no clear explanation (in a nutshell) as to what kind of system my year/model uses when in D mode, Dynamic mode and/or Sport mode.
anyone know? lol
Post #518143 Sat Feb 18 2017 7:39pm
It's permeant 4x4.
I too would like to know if it's biased to the rear etc.
Playing with snow gravvel sand knob changes the diff lock. As seen by padlocks on the display
Post #518144 Sat Feb 18 2017 7:50pm
Lonescout
2006 Range Rover Sport TDV6 HSE Cairns Blue
Here is a good explanation of how the transfer box works.
http://www.fullfatrr.com/forum/topic12404.html
Post #518203 Sun Feb 19 2017 10:30am
TheWojtek
Re: Quick Question about 2010-2013 Range Rover Sport AWD Sys
Sport mode doesn't do anything to the diffs.
RRS has a 50/50 split full-time all wheel drive with stock torsen centre diff aable to be fully locked with special programs and opptonal locking rear diff.
Yes, it is somewhat similar to quattro, but much more adjustable due to terrain response. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #518219 Sun Feb 19 2017 1:43pm
Tim in Scotland
Dynamic mode will only vary the steering weight, the monitoring of the suspension and the frequency that it adjusts and the throttle response, AFAIK in Dynamic no changes are made to diff locks. In Sport mode all that changes is that the gear box will hold onto gears to higher in the rev band until you pull the + paddle or it automatically shifts up when you get to the rev limiter, again it does nothing to diffs from my understanding. When I have been greenlaning on 22" wheels and road tyres it has surprised me how hard the rear difflock works even in not particularly challenging conditions on my L494 Dynamic, none of my previous FFRR's or RRS's had the e-diff and it is very effective on my present car in the Grass, gravel and Snow setting. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #518224 Sun Feb 19 2017 2:09pm
CANROVER
So you're saying that in sport mode the power split stays 50/50 and not a 60/40 bias to the rear wheels? I gotta wonder about that because in an empty parking lot on a snow day, if I disable traction control put it in dynamic and Sport mode The car spins on a dine if I just mash the throttle. Even if I try to take off in a straight line the back end seems to want to kick out all the time. When back in "D" with dynamic off and traction control back on I can mash the throttle and even before TC kicks in the back end hardly kicks out when mashing the throttle. This is what lead me to wonder about the power split in different modes.
Post #518228 Sun Feb 19 2017 3:13pm
TheWojtek
It's because it moves forward, not reverse. Try the same thing in reverse and you'll be throwing your front end all over the place.
The second thing is that you mistake the default 50/50 split with the actual torsen diff action (which is infinitely variable witha pre-set inital value). A torsen centre diff will direct more torque towards the axle with more traction, your front end will always have less traction if you floor the throttle (it lifts up) therefore the rear axle gets more torque and allows for rear end to sway.
My LanEvo (50/50 split) was able to rotate along an axis that would be right in the middle of the car (actually in the centre of gravity) with all 4 wheels spinning. No need to have a rear-biased split to do donoughts. Regards etc.,
Wojtek
Post #518280 Sun Feb 19 2017 8:16pm
The centre diff isn't a torsen unit, it's a normally open diff with the locking function provided by a multi plate clutch. The clutch is controlled by the Terrain Response system. The system can give fully variable locking. Each TR setting will give different locking characteristics.
Drive is normally split 50/50 but can be sent 100% to either end in response to available traction.
Interestingly, in the RRS2 without the 2speed transfer box, drive is set at 40/60 f/r I think (from memory). 2012 SDV6 - it's missing a couple of cylinders
Post #518287 Sun Feb 19 2017 8:41pm
TheWojtek
I was under impression that the centre diff is a Torsen unit with additional electronic lockup control, but might be wrong with the actual unit used. Notwithstanding with any of the above observations. Regards etc.,
Wojtek
Post #518358 Mon Feb 20 2017 2:04pm
I think the L322 FFRR had a Torsen centre diff when first produced. It changed to the same system as the D3 / RRS when it took on the Magna-Steyr transfer box in 2008(?) along with Terrain Response etc.
The RRS uses a planetary gear to split drive front to rear with a clutch pack to give the variable locking rate. 2012 SDV6 - it's missing a couple of cylinders
Post #518400 Mon Feb 20 2017 8:15pm
CANROVER
Thank You all for your replies. RRSTDV8 seems to make sense here as I can't imagine the front wheels rising enough on a 50/50 power split to throw out the back end. Afterall, the front of these things are *very* heavy. Furthermore, it did not take a huge oomph of power to make the back end fishtail on a snowy surface. Keep in mind that I did disengage Everything and set up the car for what I thought would be full power to the rear wheels. As for Dynamic mode changing the steering weight, not in mys car. It's Hydraulic steering and I'm pretty sure that you can only vary steering weight on an electronically driven steering rack. Also, there is no change in the feel of the steering.
That said I have no clue what the Dynamic setting really does. It seems that customers are given the impression that if you turn the knob to the wavy road symbol the car will adapt itself to any road condition which I find to be a pretty far fetched claim.
Post #518406 Mon Feb 20 2017 8:57pm
