![]() | Home > Maintenance & Modifications > Engine System Fault Back |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 ![]() ![]() ![]() |
Hi Lads
Hi Andy
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
When I first got mine almost 2 years ago now. I had engine system fault come up constantly, it was usually at just over 70mph, and this was happening for several months, very annoying! Then I started using vpower diesel and had a few months of very low fuel economy |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Do you not need to reprogram the ECU after blanking the EGR valves, or is that only the tdv8 ? |
Socast
Hi Lads
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
Maybe the experts can help here, but what I don't understand is that if the motor has failed in the EGR, and the ecu can see this with its feedback, why blanking the EGR's will actually make the fault go away.
Hi Lads
what codes are you getting now?
Hi Andy
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4501 ![]() ![]() ![]() |
Most likely the actuator is not free enough. I have had to work them for (literally) hours on the worst ones...
Thanks Mikey
Is the car quick to drive.
Hi Andy
