Home > Technical > Help needed !
Unclebuck
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
Help needed !
I have 4.2 Sc that seems to have issues when left overnight/ all day! The car starts first time every time, and it seems to tick over for the first the first 30/40 seconds but then it seems to start missing/juddering. I turn the motor off and back on and everything's fine, no issues and runs great. When leaving work if I leave it all day I have the same issues as the morning start, i.e.turn on,missing etc turn off and back on and everything's fine, however if I use the car say at lunch , it starts,ticks over ok,and I have no missing/juddering issues etc, and in the evening when going home the same day I have no missing issues then either ? Any suggestions ? Thanks
Post #517281 Thu Feb 09 2017 11:57pm
Hocks172
Just a guess but I had a problem that was intermittent like yours and it turned out to be a relay in the engine fuse box, not sure if something turns on or of via a relay making yours do this but just a thought? RRS Autobiography SDV6 19
Tesla model 3 long range SOLD!
BMW f15 X5 m50d SOLD!
Disco 5 HSE Lux SOLD!
Evoque Dynamic Lux. SOLD!
RRS HST Sold!
Other gonners, Disco 3, BMW 525d E60, Jag 2.2d X-Type, Merc E240, Audi A4, Peugeot 306, VW Golf GTI 1.8T mk4,Toyota Hilux, Mazda 323f, Escort 1.3!
Post #517282 Fri Feb 10 2017 8:10am
Unclebuck
Ok will check thanks
Post #517288 Fri Feb 10 2017 9:46am
coil pack? --
Post #517290 Fri Feb 10 2017 10:31am
Socast
It'll be a software update for the engine I would think. Thumbs Up
I had a similar problem that when starting the car in cold weather where when starting the engine would start as normal and then stall after a second or so. If started with a bit of throttle it would hold and be fine.
So while not the same issue as you're having it's very similar. Especially with it being a cold start issue.
Post #517293 Fri Feb 10 2017 10:59am
