Home > Maintenance & Modifications > FBH update
Wayneclarke
FBH update
ok so today my local garage unlocked my FBH and they said it had locked out on low voltage which i had kind of guessed anyway, my battery has been replaced so just have to see if it locks out again.
Post #515575 Mon Jan 23 2017 6:38pm
Eaters
So,are you saying that the fbh will not just shut off if it detects low voltage but actually prevents itself from starting again until unlocked by the garage? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #515577 Mon Jan 23 2017 6:49pm
Wayneclarke
after 3 attempts it locks out, i had my alternator go down a little while back I'm hoping it all locked out then I've put a new battery on so just have to keep watch. can't see why it wouldn't try to start after the vehicle is running and alternator is charging
Post #515578 Mon Jan 23 2017 6:54pm
Eaters
Hmm. I didn't know that. It seems a bit strange but some LR developer obviously thought its better to have no fbh but enough battery to start the car. However as you say once it's running, what's the problem?
Oh well - good to know!
If your passing a Lidl in the near future, it might be worth investing £3 in their battery and alternator tester. Not sure how good it is for that money, but might give you peace of mind to test your alternator? And, no I do not have any connection with Lidl! Smile Robin
Gone:
MGZTT 190 2.5
Post #515584 Mon Jan 23 2017 7:35pm
flack
They dont lock out because of low voltage, if the battery is low they just wont start. What will lock them out is low fuel, if you have less than a 1/4 tank it will not run, it goes in to lock out mode to save fuel after three failed starts.
Some cars can be reset by removing the fuse, but not all, others need a diagnostic tool to reset the FBH.
Flack Thumbs Up
Post #515628 Tue Jan 24 2017 12:22am
Wayneclarke
Less than 1/4 of tank oh right I thought low fuel was meant by if the light was on, when Bodsy unlocked first time is was because of low fuel this time the garage said it was locked out due to low voltage ???
Post #515637 Tue Jan 24 2017 4:30am
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
How does the regular Joe know if his FBH has locked itself into cryostasis?
White smoke from the front left wing doesn't always come, but a fuel burning smell does. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #515641 Tue Jan 24 2017 8:28am
RallyXS
Flack Thumbs Up
Mine was working the other day and I was just over reserve, so not sure about this not working under 1/4 tank. 2012 RRS SDV6
2014 BMW 320d X-Drive Touring
1999 VW Polo stage rally car
Post #515876 Wed Jan 25 2017 11:45pm
