![]() | Home > Maintenance & Modifications > What is this |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
Aftermarket.
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Looked like it went into the fuse box.
would like a pic of what's under the fuse cover then |
So, had a butchers at what his might have been. i was wrong. It didn't go into the fuse box. it goes to the back of the battery and then runs across the engine bay to the other side and then disappears into the cabin (i believe), but there is nothing inside the cabin extra. i installed the Parrot Mini Asteroid. Possibly previous owner had something and removed it.
Disconnect it, while stationary of course, and then run a complete systems check, you should soon find out what, if anything, it was. John
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
Could be an aftermarket power feed for a dash cam. I'm in the shed, I'll be back in the real world in a minute.
