![]() | Home > Technical > Loud vibration inside the car (engine off too!) |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1557 ![]() ![]() ![]() |
Before I start , just to say that I am no expert by any means. And I've only had my RRS since March so no great experience with them so this might be worth zilch.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
The rubber bush around the carrier bearing on the prop is renowned for going. Get it on a ramp and check that.
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, as Socast has said check the rear prop bearing its a common fault, went on mine now fixed and fine |
