![]() | Home > Technical > 15.2 volts from alternator. |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
2005 RRS TDV6 HSE
Thanks for that, will try in the morning and report back.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4515 ![]() ![]() ![]() |
15.2v is perfectly normal |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 ![]() ![]() ![]() |
Every morning my radio and satnav would play up for a few mins. Noticed if I put heated screens on the worked fine. I got a put in voltage reader and it was pushing over 16 volts for first couple of minutes then settled around 15 volts. Got a new alternator fitted and all is fine. |
Thanks for your replies.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Why |
You may find the regulator rectifier is on the way out. If it's not causing problems leave it alone until it starts to play up with your electrical systems. |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
Thanks for all your replies. I will take the reader out of the charger socket and enjoy driving the car.
