![]() | Home > Technical > Can active cornering lights be turned off via diagnostics |
I thought Active Cornering was ACE - part of the suspension system - do you mean ADAPTIVE headlights with cornering spotlights that come on below 30mph to illuminate corners / kerbs? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
highfellzippy Member Since: 06 Dec 2009 Location: yorkshire Posts: 256 ![]() ![]() |
Yes AFS
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
The adaptive part can be disabled, while retaining the corner lights, or the whole lot can be disabled |
Or don't use indicators also stops them coming on. |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1557 ![]() ![]() ![]() |
My cornering lights come on at low speed whether or not I use the indicators Robin
Mine come on under 30mph with indicators on, but I've not actually notice if they do it automatically. |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
My 2009 used to come on without indicators, but my 2010 only comes on with indicators.. |
IIRC they should do both, with indicator on or at less than 30mph if the steering wheel is turned by a certain amount - when I had them on my Evoques and the TDV8 RRS they came on at night when I was negotiating twisty local country back roads at less than 30mph and also going up and down the access ramps in multi-storey car parks. Passengers sometimes used to remark about the "little light" that came on when I was negotiating turns. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 958 ![]() ![]() ![]() |
Mine come on all the time,, didn't realise they only worked at less than 30 mph but sensible when you hint about it! 2010 RRS, TDV8
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
#numpty_question: My pre-owned L494 (MY15) Autobiography Dynamic doesn't seem to have what I assume are called Active Cornering Lights; what should I look for on the dash to confirm this?
There are some cars that have to have a recall applied to make them work - some late 2015MY and early 2016MY Autobiographies IIRC. They don't need any enabling in the dash menus. Best way to find out is at night to turn on the headlights, turn the steering wheel to full lock and see if you can see the small spotlight in the headlamp unit come on, it can be seen from the driver's seat 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
mine come on without the use of the indicators, but only on sharp bends 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
