![]() | Home > Maintenance & Modifications > Replacing ACE pump |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I've done it on the 4.2 SC and it's not too bad. You need to remove the wheel liner and a small part of the under tray. Not sure if the pump is in the same location on the TDV8 though. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
According to the book of lies, you need to remove the cooling fan and the generator (alternator) to change the dynamic response pump.
