Home > Technical > Fusebox Towing, Light right side.
Betonklinker
Netherlands
I have a problem this week... no normal lights on my trailers at the right side, left side and numberplate lights is OK.
In the boot is no towing fusebox, any one now where else?
The cornerlights and breaklights, normal working left and right, but not the 'normal' lights Sad (problem whit all trailers I have try'd, and the bulbs are OK Wink ) Now - RRS L320 TDV6 Stornoway Grey
Old - FFRR L322 td6 Bonnati Grey
Post #511994 Sat Dec 10 2016 6:11pm
Need to check the wiring in the boot on the left
And in the socket.
What year car?
Post #511996 Sat Dec 10 2016 6:22pm
Betonklinker
Netherlands
2007 Now - RRS L320 TDV6 Stornoway Grey
Post #511997 Sat Dec 10 2016 6:23pm
Betonklinker
Netherlands
The problem is solved, a broken fuse. The towingfuse box with me in the car's is behind the left rear interior panel in the boot.
Chance fuse 5 Ampere and everything works again. Mr. Green Now - RRS L320 TDV6 Stornoway Grey
Post #512738 Wed Dec 21 2016 5:20pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hmm..
Are the techies sloppy?
I had the same "problem" on my car..
The fuses were not where they was supposed to be.
Under the floorboard, where the jack and tools are stored,
lower left corner, the fuses s h o u l d have their home.
On my car the "techie" (the guy/girl/thing) that installed the
towing electrics, had just left the fusebox on the inside of the rear wing,
behind the interior panel.
Have relocated it to itīs proper place now..
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #512758 Wed Dec 21 2016 10:44pm
Sounds like they fitted it where it goes on the disco
Post #512759 Wed Dec 21 2016 11:11pm
Betonklinker
Netherlands
Yes.. its a very strange place to put a fusebox Sad but I have no more problems Smile Now - RRS L320 TDV6 Stornoway Grey
Post #512813 Thu Dec 22 2016 4:26pm
