Home > Technical > Drivers Side HOT / Passenger Side COLD
alextecreed
United Kingdom 2008 Range Rover Sport TDV6 S Bonatti Grey
Hi, i recently purchased my RRS 2008
tested the heating and had it turned all the way up on both controls (passenger and driver)
and comes out cold on passenger and hot on driver, same on the back vents, and floor vents
any ideas?
Post #511654 Tue Dec 06 2016 2:50pm
DrRob
Throw it back at the dealer you bought it off....? Visitor from fullfatrr.com
Post #511662 Tue Dec 06 2016 6:37pm
HemoRRS
You can try this
Distribution motor self-test
The motor and flap operation can be checked using the on-board distribution motor self-test function.
The self-test can be initiated by pressing and holding the ECON and RECIRC buttons while turning the ignition switch to the ON
position.
The control module will then compare the current motor position with the values stored in the module and will indicate an error by
flashing the ECON LED (light emitting diode).
If there are no errors, the LED will go out and the system will function normally.
To confirm that there are no errors, turn the ignition switch to the OFF position, then back to the ON position.
Observe the operation of the programmed defrost LED.
If there are errors present, the programmed defrost LED will flash and the system will attempt to calibrate itself.
For additional information on the function of the system, refer to the relevant section of the workshop manual.
Post #511663 Tue Dec 06 2016 6:43pm
Ljdiscovery
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
It is probably the Servo motor on the lower left side of the hvac box at the bottom of the center console. Check the lower motor on the left side. Your passenger side. Mine died and I am waiting for a new one. You can remove the motor fairly easily. you can manually flip the flap that diverts the ac and heat on the left side of the truck. Phil
2006 Range Rover sport hse
2005 lr3 hse
Post #511703 Wed Dec 07 2016 7:30am
