Home > Technical > u3000 code help please
nosmokenopoke
United Kingdom 2009 Range Rover Sport TDV6 Autobiography Zambezi Silver
Evening all
I have a u3000 code on my rrs 2009 2.7. Its stuck in 3rd (Limp) F fault on display after 2/3 seconds of turning the ignition on.
Now i know the code is generic but my Delphi diagnostic wont work that well to tell me what last two digits are missing
I am in need of the codes which represent U codes
also after some info on a cheap software so i can buy just to sort this.
Thanks Jon
Post #511315 Thu Dec 01 2016 9:15pm
Workshop manual says:
Quote:
U30004A
Control Module
Incorrect component installed
- Mismatch between
configuration data and read
configuration
Configure the module using the approved
diagnostic system.
Sounds like you need to take it to someone with the right diagnostic kit who knows what they're doing. 2012 SDV6 - it's missing a couple of cylinders
Post #511337 Fri Dec 02 2016 1:33am
Orange RRS
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
U codes are generally communication errors between modules and normally there are lots of them logged. Have you tried clearing it and reading it again,
If it's a hard code it may be relevant Life's too short to drive boring cars !
2005 Supercharged First Edition
2013 Evoque
Post #511353 Fri Dec 02 2016 10:00am
