![]() | Home > General (L494) > MY17 Remote park Heat |
qwick69 Member Since: 09 Aug 2016 Location: Hertfordshire Posts: 22 ![]() ![]() |
I didnt order the park heat option and the App still works for me. |
Silty Member Since: 01 Dec 2016 Location: Aberdeen Posts: 59 ![]() ![]() |
Park Heating and the ability to start the engine from an app are two very separate things. Park Heat remains an option but if you haven't paid for the £1000 option you won't have it. You will however, be able to start the car remotely and therefore create heat (or cold) as you wish. 2017 SDV6 Autobiography; Carpathian Grey, Ivory, Soft Close, Extended Grand Black. |
Jimbo095 Member Since: 21 Sep 2016 Location: Lincolnshire Posts: 145 ![]() ![]() |
So what exactly is park heat and what are the benefits over normal remote start heating/cooling? Is it an auxiliary heater run off the battery as mentioned? Surely seems a waste to spec now? |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 ![]() ![]() |
Remote start was originally going to be released in MY16 but the feature was dropped. I always thought this was due to emissions regulations but if it has been made available in MY17 then regulations can't be the reason for ditching it last year.
"Now with remote start I think the car will just behave as it would if you were idling so whatever your climate settings were at the time of leaving the car would resume. It does make remote climate less attractive IMHO based on my above understanding."
Cheers peeps, the front/rear heated screen activation was my next question! If anyone can confirm whether this is possible, along with the activating the heated seats and steering wheel via the app, that would be great... |
Reading the above, park heating doesn't seem to offer much in MY17 that remote start doesn't. Even if remote start doesn't turn on heated screens, the heat inside the car will soon defrost the glass. Heated seats and steering wheel are only useful when the car is cold. I never need to turn on seat heating or steering wheel heating if I have remote heating running. Same will be the case with remote start I imagine. You can't start remote heating if the car is in a garage or indoor car park because it produces fumes, although much less than a full running engine. One should be ok to use remote cooling indoors because it only uses battery and no fuel but we really don't get cars that hot unless they have been sitting in the sun for a while. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Park Heat is a more discreet option compared with conspicuously running a diesel engine. It's easier to think of it like a central heating boiler, fuelled by diesel. Obviously it can heat the car but its only cooling function is to use the car's fan to circulate ambient temperature air around the cabin, i.e. it does not activate the air con. It can also be used if the car is parked up with people onboard to keep the cabin warm without running the engine. Whether it's worth £1000 to be a little less vulgar than running a large diesel engine is your choice.
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 ![]() ![]() |
Regards front a rear screen you may not be able to set them via the app but when the outside temperature is low when you start the car they come on so I assume starting via the app is the same.
That's a fair justification! Presumably there is some kind of fail safe if this were to happen as the keys are nowhere in the vicinity? Remote switch off the engine??
