Home > Maintenance & Modifications > iPhone connector???
Richard039
England 2007 Range Rover Sport Supercharged HSE Java Black
iPhone connector???
Hi
I've just bought a 2007 RR supercharged, which has an old Nokia telephone connected in the chubby box. What is the best way to connect my iPhone 5 to the car so that I can control it through the steering wheel controls?
Thanks Richard
Post #510920 Mon Nov 28 2016 1:26am
enable Bluetooth on the phone.
If you find anything use pin 2121 or there is another pin
Post #510944 Mon Nov 28 2016 1:05pm
Tim in Scotland
If there is no B/T then I can recommend retrofitting a Parrott in car hands free phone system, they are much more versatile than the RRS system from 2007. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #510945 Mon Nov 28 2016 1:07pm
Richard039
Hi
Thanks for the tips. I enabled Bluetooth on my phone but it never found the car Bluetooth. I have heard that I have to turn that on, if so how and I have heard that some 2007 models never had Bluetooth. They had the old Nokia phone hard wired in instead (which I have).
If that's the case a parrot it is then.
Post #510961 Mon Nov 28 2016 4:56pm
Bodsy
Site Sponsor
If the Nokia is underneath the armrest cubby lid, then it's the factory kit, which includes blutooth.
Switch on the BT on your phone and search for new devices on the phone.
You should find LandRover
Select it and then enter 2121 as the pin.
It won't stream music (which will be your next question... Wink ) Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #510962 Mon Nov 28 2016 5:08pm
Richard039
Hi
I swithed on the Bluetooth but it found nothing but will try again when I get home from work
Thanks
Post #510968 Mon Nov 28 2016 5:48pm
Richard039
Iphone connector
I have tried using several different phones and none of them can even find the Land Rover connection so I can't even attempt to pair with it.
The Nokia, which is in the cradle has no SIM card in it and the only message that come up is telling me this.
Post #511134 Wed Nov 30 2016 10:45am
You could get a free sim from ASDA for it. (order on internet). Comes with 10 free minutes.
Will tie you over until you get something else sorted.
Post #511158 Wed Nov 30 2016 1:37pm
shakeapaw
I dont believe you cant use the two systems at the same time, remove the phone from the cradle, wait a while, then try the BT pairing again 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #511179 Wed Nov 30 2016 4:19pm
Richard039
iPhone connector
Thanks for that your suggestion worked Very Happy
Post #511458 Sat Dec 03 2016 10:52pm
Richard039
iPhone connector
Post #511459 Sat Dec 03 2016 10:53pm
typhoo12
Mine isnt finding the "landrover" and just brings up handsfree. When i try to pair it says it needs to be within range and turned on to find? Any ideas what the problem may be?
Post #511832 Thu Dec 08 2016 1:33pm
shakeapaw
the Landrover BT module turns on with the ignition, if that is faulty then it wont connect, see if you can find a BT untit in a scrap yard or borrow one? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #511833 Thu Dec 08 2016 2:02pm
Richard039
Iphone connector
To cut a long story short I started my RR up, took out the Nokia phone from the chubby box and waited about 5 minutes then I searched for the land rover and it worked. With the Nokia connected to the RR it wouldn't work. The hands free you've found is most likely not the RR. Hope this helps
Post #511844 Thu Dec 08 2016 4:45pm
