![]() | Home > In Car Electronics > Tracker - After ignition live lead under the bonnet |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
Green wire under the fuse box. |
You want to install a tracker, but only works with ign on.....? Why....? Bodsys Brake Bible
ibartsimp Member Since: 17 Nov 2016 Location: bordeaux Posts: 21 ![]() ![]() ![]() |
No it has a battery so it will only charge when ignition is on
trackers are normally hooked up to a battery supply, which is the thing to do.
Mine is powered through a usb adapter so I have to add a 12V adapter and then hook the whole thing together.
For the record, I may change my plan and use the 12v plug in the trunk, I just have to figure out
