Home > Maintenance & Modifications > How long should my brakes last?
dpg123
Hi all,
Can anyone advise me how long I can expect my brake discs to last, and how long the discs? it's a 2010 TDV8.
Thanks!
Post #509822 Fri Nov 11 2016 11:34am
Paddi
Depends to large extent on driving style and the type of journey. Last changed all the discs and pads on mine about 30k miles ago and the pads look to be about 70% worn. I'd expect the discs to last that distance again with new pads, especially if the lip is ground off when new pads fitted.
But then again I do drive with a great deal of sympathy (for which read 'like an old granny') most of the time.
(Oh dear probably started another controversy now. People will say you shouldn't grind off the lip but I'm convinced if it is done carefully it is fine.) 2008 MY Java Black TDV8 HSE
Post #509834 Fri Nov 11 2016 1:54pm
Orange RRS
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
brake disc wear is dependant on a number of different factors rather than just how the car is driven.
I live 100 metres from the North Sea and have corrosion on my brake discs in a couple of days, obviously off roading can damage them with stones getting stuck behind the mud shields
Beware of cheap brake pads they are often very hard and rapidly accelerate disc wear.
Most sensibly driven vehicles should do a set of brake pads before discs need replacing as a worse case scenario
The problem with longer service intervals is that as the car is serviced every 15,000 miles rather than 7,500 miles if the pads are half worn they may not last to the next service. So they may be reported as need replacing but will easily do another 10,000 miles.
I expect at least 30,000 miles from front discs and more for the rears. Life's too short to drive boring cars !
2005 Supercharged First Edition
2013 Evoque
Post #509835 Fri Nov 11 2016 1:57pm
Mail Order Ride
Ex TDV8 here
Sold at almost 60k miles on original discs
Pads lasted me 40k
This may be a record according to my tame indie Smile
Post #510040 Mon Nov 14 2016 2:17pm
shakeapaw
my rears last 10k, and my front last around 20k, original brembos as well, we have a lot of country roads near me, and as i set off to work at 5am, the winding roads are clear, so VERY late brake into corners, in sport mode kills my brakes, am I bothered...............no Thumbs Up 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #510230 Thu Nov 17 2016 2:07am
Charliecloud
Why would the rears only last 10k when the fronts are doing 20k ? Surely the bias is set to the front
Post #510235 Thu Nov 17 2016 10:35am
shakeapaw
Sticky passenger side calliper the first time, Censored ebay pads the 2nd time, even worse local motor factors pads the 3rd time, Im now using genuine Brembo pads 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #510262 Thu Nov 17 2016 6:01pm
RichG
Australia 2008 Range Rover Sport TDV6 SE Chawton White
I have about 90k km on front brakes and pads, they are pretty close to done.
Rears have about 60k km and probably 40-50% worn.
Car does lots of all types of driving - city, highway, b-roads, and a fair bit of towing. MY16.5 RRS SDV6 AB Carpathian Grey/black 154k km
MY08 RRS TDV6, Chawton/Black, sunroof, hk, 370k km
MY10 Audi A6 3.0T - Stage 1 - 210k km
1990 Nissan Pintara TRX, lots of mods, 438k km
Post #511621 Mon Dec 05 2016 11:55pm
