Home > General > MOT Advisory
Charliecloud
MOT Advisory
Looking at a MOT report on a 2005 RRS 4,2SC and it states 'fuel tank cradle corroded'
Is this a big concern? Is it an easy fix?
Post #508857 Fri Oct 28 2016 5:10pm
m8ch1n
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
It's a problem if it gives way with a full tank of fuel Shocked
Usually just couple of steel strap supports with something like an M12 bolt either side holding up a tank.
Can't say for sure on a RRS if it's the same set up but they're all usually similar. Can't imagine it's too expensive to replace.
Maybe just consider what else maybe corroded underside but it wouldn't bother me too much if I saw that. Just give it an inspection on viewing. Current: RRS 2010 L320 Facelift 3.0 TD V6 HSE 5dr Alaska White
Gone:Mercedes C220 Estate AMG MY 9/2012 Polar White
Gone:Mitsubishi L200 Raging bull edition MY 9/2009 2.5l DID Red
Gone:BMW 116i MY 4/2006 Silver
Post #508865 Fri Oct 28 2016 7:36pm
They are a full tank cover on the RRS.
Have a look under the drivers side by the doors.
Post #508866 Fri Oct 28 2016 7:49pm
Disco_Mikey
Corrosion is fine. It's a big steel plate under the car, exposed to the elements
This however, is not OK...
Post #508867 Fri Oct 28 2016 7:54pm
Charliecloud
Thanks guys, I guess a good look will tell if it's as bad as the one in DM post Shocked
Post #508873 Fri Oct 28 2016 9:09pm
Charliecloud
Just in case it's a replacement job, how much for a new one from LR
Thanks
Post #509349 Fri Nov 04 2016 10:32pm
Johnski
RRS Genuine Fuel tank fitting kit, Part No.: DHB500370 is £70.96. Price from Rimmer Bros, but try our sponsors, such as Duckworth Parts, for a possible better price. Not sure if this is the correct part for your car, but gives an idea on cost, pipes, connectors etc are extra of course, as required. http://www.rimmerbros.co.uk/ItemSearch--se...r--srcin-1 John
Post #509350 Fri Nov 04 2016 10:51pm
Disco_Mikey
Not sure where that part number came from, but I make it a WFN500021, with a retail price of around £135 + VAT, plus the required bolts and captive nuts that will likely disintegrate upon removal
Labour wise, I think it's approx 3 hours. Last one I replaced was £300 inc fitting
Post #509352 Fri Nov 04 2016 11:08pm
Charliecloud
Thanks guys- useful info
Post #509368 Sat Nov 05 2016 10:28am
