Home > Technical > Belt Question??
Sit
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Belt Question??
Morning,
Quick belt related question regarding the TDV6 - I understand from research that both drive belts are changed typically at 100k. I have seen a car that I am interested in buying which had both belts changed at 60k, that being the case when would they be due next??
It has a full documented service history and bills to verify both belts were changed at 60k, its now on 80k so one would assume the next belt change would be done at 120k??
Si
Post #508391 Sun Oct 23 2016 10:57am
Tim in Scotland
Was it more that they were changed at 7 years - on elapsed time rather than miles? I cannot remember offhand if it is 7 or 10 years for TDv6 engines. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #508393 Sun Oct 23 2016 11:18am
Rich
It's 7. Mine is due and I'm saving up!
Post #508396 Sun Oct 23 2016 11:46am
Sit
Oh ok that makes sense, thank you for the info. So on an '05 it would be 2012 and then 2019?
Si
Post #508398 Sun Oct 23 2016 12:28pm
SRE
Spain
It's a brave (and wealthy) man who waits 7 years for a belt change. Broken belt = broken Bank account Big Cry In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #508399 Sun Oct 23 2016 1:03pm
SRE
Spain
Should add, it's a tad cheaper to replace the Belts on a 2.7 than it is on a 3.0. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #508400 Sun Oct 23 2016 1:05pm
Disco_Mikey
7yr/105k miles for the 2.7
7yr/112k miles for the 3.0
Post #508407 Sun Oct 23 2016 1:52pm
Sit
Thanks for the info, of course I realise these schedules are 'suggested' but as with most things people have them done earlier so will bear that in mind. I guessing both belts are going to be circa £700 for change at an Indy?
Si
Post #508408 Sun Oct 23 2016 1:58pm
SRE
Spain
Why not have a weekend break in Scotland, see if DM can do you a belt chane and a gearbox flush. Thumbs Up Mind you, make sure you take an umbrella Big Cry In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #508411 Sun Oct 23 2016 3:21pm
SRE
Spain
As a matter of interest Mikey, how much for a 3.0 belt change Question In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #508413 Sun Oct 23 2016 3:23pm
Disco_Mikey
3.0 belts are £750 inc VAT, for all 3 belts, idlers, tensioners etc Thumbs Up
2.7 is £400 Thumbs Up
Post #508415 Sun Oct 23 2016 4:08pm
HemoRRS
I had mine done at Stafford Land Rover for £669, cheaper than any Indy I found.
http://www.swanswaygarages.com/land-rover/...elt-offer/
Post #508428 Sun Oct 23 2016 6:55pm
