![]() | Home > Maintenance & Modifications > 57 plate (08MY) L320 - Cam belt + oil pump?? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Yes, have it done. Without doubt
ramsden78 Member Since: 15 Sep 2016 Location: Romford Posts: 37 ![]() ![]() |
Thanks Mikey.. Just to check the £650 is including the front cam belt? Please tell me its not £650 just for the oil pump, and then another £350-£450 for the cam belt?? |
R4zb3rry Member Since: 28 Feb 2015 Location: Leicester Posts: 43 ![]() ![]() |
Should be £650 for the lot from Indy or £1000 if you fancy lining your dealers pockets. |
£650 for the lot. Pump, front and back belts, idlers etc |
So been quoted :
£568 for belts + an extra £636 for pump? |
Yep - £568 for belts + an extra £636 for pump. These prices are from two independents.. |
Ouch |
Any recommendations in Essex that will do for a reasonable price? |
Anyway of confirming if the oil pump has been changed in the past. Visual differences between old and new? |
Mike - Does this also affect the 3.6 or not? |
No, 3.6 is chain driven |
