![]() | Home > Maintenance & Modifications > GAP IID tool |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 ![]() ![]() |
IIDTool will let you do those things. Check out the full functionality list for your specific model here. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
For 3 flash indicators, you need to carry out a BCM update, and then a CCF edit, both of which the IID is capable of. The BCM needs extra precautions when flashing, to ensure the battery voltage stays high enough during programming to prevent any issues |
Kizza123 Member Since: 25 Aug 2016 Location: Lincoln Posts: 53 ![]() ![]() ![]() |
Thanks guys. I have seen the option for enabling the settings using CCF updates but not sure how to carry out BCU updates? |
ECU Flash>BCM |
Cheers I will give it a go. Does it automatically have the software update on the tool ready? |
Yes, providing the tool has been updated to its latest firmware. Easily checked via the Updater tool |
Boom all sorted ! I now have 3 flash indicators |
The IPC reflash gives you the clock in the message centre of the IPC, instead of just the radio |
Awesome I'll give that a go too lol. Going to try satnav on the move too |
Hey guys.
IPC 07>on will give the FBH "lights on" |
Hey mate.
Guys? |
What option did you select? Bearing in mind there are 3 to choose from
