![]() | Home > Maintenance & Modifications > 2 new tyres fitted then emergancy stop required...! |
BenDE1 Member Since: 03 Aug 2016 Location: Derby Posts: 4 ![]() ![]() ![]() |
Hi all,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Extreme vibration could be a loose wheel. Had that recently and it is quite severe. Not sure why that would cause high temps in the brake though. Only thing I can think would be the brake binding which might happen if they caused some damage but how they could is beyond me. 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5137 ![]() ![]() ![]() |
May be beyond you Wayne, now Kwik-fit that is an entirely different matter. |
Good point Col |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
Its got me intrigued, bad vibration, heat up. I guess wheel bearing, but that would just not fix itself after second inspection, and too spooky after just having tyre changed. My other guess could the calliper got a real big clout when they dropped the wheel off and dislodged a pad of something (would that even be possible?), and the vibration was either pad loose and binding/jumping around in the calliper (causing the heat and banging) or the wheel was not done up tight, but that would then require 2 major fouls in one job |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Do you use the EPB?
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Disco Mikey is spot on , as always. It would have been the electric parking brake binding, I have had the same thing happen to me. Once it had cooled and probably the shoes inside the rear disc had settled to a point where they just clear the disc bell, all is well again. I suspect that the shoes are partially seized, or there is a lot of rusty scale build up inside the disc.
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
You don't need special tools to re-calibrate the E-brake drum pads and this video proves it.
chilly Member Since: 07 Dec 2010 Location: north east Posts: 192 ![]() ![]() ![]() |
hat disco mikey said mine did the same mate and tried to through me off the A19 as one side locked on managed to lim home but the vibration and hub as you said was same only the dead truely know peace,
Quite right, but it would have been beyond the scope of Kwikfit anyway. Better to go elsewhere. |
I thought all KwikFit staff had undertaken a full half hour training course |
