![]() | Home > Maintenance & Modifications > Face Lift Question - Wheel Arch Liner Upgrade Or Not? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5138 ![]() ![]() ![]() |
According to Parts List the Pre-Facelift part no. has changed to the same as Facelift model so would assume they are interchangeable, but guess anyone who has done conversion would be in better position to answer.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Great, one less thing to worry about while sourcing all my AB parts |
When I did mine the inner wheel arch liner fitted but was a little tight |
Cheers Peachy
Fronts are ok. Rears won't you need one's specific to fit A/B bumper. P/No. VPLSP0015
As above - front ok - rears are a different part number |
Another part to add to the list |
Forgot to mention on the same powerful uk vid when taking of the wing they also replaced a plastic and foam piece from the part of the wing which they also sell as part of the conversion kit "Range Rover Sport 2010 Conversion Front Wing Fitting Kit", is this foam kit vital or not when replacing newer wing?
Replied to your pm - yes I did fit them - they are a factory fitted part so why those conversion companies omitted them is beyond me - where else have they cut corners ?
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 ![]() ![]() |
The plastic part is slightly different - holes don't match the new wings, I drilled the plastic trim to adapt to the new wings. The new foam was ordered from Dan. I suggest you use Dan, his was a little cheaper than powerful.
Thats why I did not want to use one of these companies, who knows what other short cuts/damage they will end up doing to your car ![]() EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
mnk your car is looking great, did you have any problems while you were facelifting your car?
