Home > In Car Electronics > Blown.........and missing fuse ?
Paul_selby
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Evening all . Just been replacing all the 501 type bulbs for led replacements , got to the last ones (the rear map reading ones) and I have let the contacts touching, blowing a fuse . I don't have an owners manual to hand , and have found the interior fuse box but can't make out which fuse would be for the interior lights . Whilst I was looking I noticed there is a fuse missing from position 52...............any help appreciated Bow down Bow down
Post #505547 Thu Sep 15 2016 10:03pm
It's at the top.
Maybe no 2 or 5
Post #505553 Thu Sep 15 2016 10:27pm
Paul_selby
Thanks Andy , I'll have a look 1st thing tomorrow
Post #505557 Thu Sep 15 2016 10:47pm
Fuse No.1 Top left
http://www.rrsport.co.uk/forum/topic44340.html
last post
Post #505590 Fri Sep 16 2016 12:06pm
Paul_selby
Spot on Andy thanks . Just a note to anyone changing the rear map lights from bulb to led........if the LED have a metal housing they will blow the fuse. There are 2 stabiliser bars that help hold the standard 501 bulb in place , but these (now I can see in the daylight Very Happy ) are connected to the live and earth connection, so either need to be bent slightly open or snipped off . Hope this helps some to not make the same mistake I did ! Thanks for the info Andy
Post #505608 Fri Sep 16 2016 2:35pm
Paul_selby
Post #505611 Fri Sep 16 2016 3:06pm
