![]() | Home > Maintenance & Modifications > Front window washers |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
It's certainly interesting that the rear one still works. It uses the same pump and filter,. IIRC
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 ![]() ![]() ![]() |
Yes def pump running when push button on stalk, I even took headlight out and got someone to push washer button and can hear pump running, I also disconnected pipe from passenger side jet and blew hard down pipe and clearly heard washer fluid bubbling away in washer bottle so pipes seem to be clear and connected,
Water shouldn't come out the rear when the end button is pressed.
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
Yes, it's the same pump running in different directions for the front/rear. The button on the stalk should be for the front, so there must be an electrical issue somewhere - with those results it must be either with the switch, or wiring from the switch to the CJB (passenger fusebox). I think your symptoms rule out any issue with the pump/pump wiring so keep the bumper on. |
Will try electrics reset, will also do scan first just to see if anything comes up. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5138 ![]() ![]() ![]() |
That's quite strange on my facelift push the button operates rear washer, pull the stalk operates the front washers. Cheers Col |
Just read codes and came up 1) battery saver relay output circuit B1C62-14 & front windshield wiper fast relay coil circuit B1C76-14 cleared them & front washers worked for couple seconds then stopped again, read codes again and no codes present, |
On the early ones the button is for the front |
May need a few cycles for the codes to return.
Yes all settings work on wipers, disconnected battery for 10min, no joy, if I hold washer button all I hear is motor (& rear washer pumping out water) but if I blip the button ( on off on off continues) it squirts a little bit from both front, I can also hear fuse box clicking away on every press.
Clicking could be a relay, might be worth checking and see if you can swap it for another one if there is one the same.
Thanks will give that a check, if not obvious witch relay is wiper/washer shall I just do it by process of elimination. Remove relay try washer button and so on until I hear no click on pressing washer. |
If you get someone to operate the stalk and you put your finger on various relays you may be able to feel which one is clicking.
Great, thanks col. Will give that a go. |
