![]() | Home > Technical > P0730 p0735 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5114 ![]() ![]() ![]() |
So you have had the problem with no drive ?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9109 ![]() ![]() ![]() |
P0730 and P0735 are "incorrect gear ratio" and "gear 5 incorrect ratio" respectively. This points to the speed sensor (in the gearbox) according to the manual. Check the sensor for errors and the wiring for issues.
Sounds like the mechatronic unit faulty, not getting the pressure right. So the solenoids start to fail. Or it could be the actual gear rings themselves. Either way, sounds like it needs replacing.... Bodsys Brake Bible
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Not to hijack the thread, but whats SNOTM ? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5115 ![]() ![]() ![]() |
Calculated guess, Sat Nav on the Move.
That's right, allows pre 2007 navigation systems to be able to change the destination whilst moving. Before 2007, you had to stop to change the destination. |
