Home > Technical > Htd Front seats - or lack of
andywatson
Hi gents,
Front seat switches light up but no heat, any pointers as to what to look for?
Would a blown fuse still allow the switch indicator lights to work?
Rear seats and steering wheel heating is working fine
Thanks 2008 RRS 3.6 HST - Stornaway / Black - Current
2010 RRS 3.0 HSE - Nara Bronze / Almond - Gone
2009 RRS 3.0 SE - Sliver / Teal
Post #504545 Mon Sep 05 2016 1:32pm
ilard
I would not have thought the dash button lights would light up if the fuse had gone, but worth checking:
Fuse 24 (engine compartment box), 25 amps (white)
You could try switching it with the rear seat heater fuse:
Fuse 8, also 25 amps
The heated wheel is on a separate fuse. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #504546 Mon Sep 05 2016 2:02pm
andywatson
Thanks ilard, that was my thinking too - lights wouldn't work if fuse had blown.
Will have to check though Thumbs Up Thumbs Up 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #504548 Mon Sep 05 2016 2:07pm
Probably needs a new element in the seat base. The base and seat back elements are in series so one failing takes out both. The switch will still light however. 2012 SDV6 - it's missing a couple of cylinders
Post #504553 Mon Sep 05 2016 3:06pm
andywatson
Thanks RRSTV8, So do you think just unfortunate that both seats have a fault? 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #504563 Mon Sep 05 2016 3:40pm
Sorry, didn't realise it was both seats. That would be unfortunate indeed. 2012 SDV6 - it's missing a couple of cylinders
Post #504639 Tue Sep 06 2016 7:53am
andywatson
Faulty front seat heater control module was the culprit 2008 RRS 3.6 HST - Stornaway / Black - Current
Post #509357 Fri Nov 04 2016 11:19pm
Johnski
Always good to get feedback, and hear a positive result and the reason/part causing problem. Thumbs Up John
Post #509361 Sat Nov 05 2016 1:10am
