Home > In Car Electronics > Hella LEDaylight 4 DRLs
Guyzer73
Well had the car in for a service and after they overhauled both the Supercharger and EAS Compressor with the requisite kits I got the folks to install the Hella's.
Have to say well happy with the result looks very OEM. The lights don't go out with the dipped headlights, rather dim themselves. With side lights on they are full brightness.
Enjoy:
Have a good weekend
Post #502752 Sat Aug 13 2016 5:42pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Very nice, and i do love that colour.
Post #502892 Mon Aug 15 2016 1:55pm
Guyzer73
Cheers Dan Thumbs Up
Well the Hella's on for a couple months now and was confused why they seemed brighter when turning a corner.. so on investigation I realised the mistake I made. Censored
Basically, the Hella's where mounted flush. unfortunately being flush meant they where approximately 15 degrees off being perpendicular to the longitudinal axis of the car. Therefore the full light effect was pointing slightly to the side and not the front.
To rectify I got hold of Hella LEDayline 15s. These are 8 LED units angled at 15 degrees. Slightly larger, but here they are:
They now fit across the whole width of the 'air intakes' and are clearly visible duringthe day. My only complaint of note is that they are a warmer colour than the others but hey ho safety first...
Enjoy
Post #507905 Sun Oct 16 2016 10:12am
mnk
Hi Guy, drls look great. Can you provide a sketch or explaination on how you wired the drls.
Post #507913 Sun Oct 16 2016 11:18am
Guyzer73
MNK, sorry for the late reply I got side tracked. Anyway, I didn't install them the garage did and they unfortunately haven't got the instructions anymore.
Try a Google search and you should find the relevant Hella instructions though. But I suspect any LED DRL installation guide should work.
Regards
Post #509941 Sun Nov 13 2016 8:28am
Betonklinker
Netherlands
Thumbs Up Cool Nice! Now - RRS L320 TDV6 Stornoway Grey
Old - FFRR L322 td6 Bonnati Grey
Post #510053 Mon Nov 14 2016 4:57pm
Blueskye1
Wales 2008 Range Rover Sport TDV6 HSE Java Black
Just a suggestion head for the Hella site Shocked
Will also help with legal requirements distance apart & height page 19 English on PDF etc Thumbs Up
http://www.myhellalights.com/files/9613/68...1.PT85.pdf
Andrew My first RRS HSE Purchased June 2016
Java Black 2.7
Date of first registration 22 February 2008
Cousin of the King of Stamford Bridge R.I.P. Ossie
Post #510055 Mon Nov 14 2016 5:14pm
Guyzer73
Andrew,
Ironically the Hella site doesn't provide the details of the LEDayline 4 DRLs that I installed initially and these had the dim function in lieu of the on-off most DRLs have
, and the the LEDAyline 15 DRLs have.
I've actually used the Dayline 4 wiring and connected the 15s to it so that I retain the dimming function when the heads are on.
Regards
Post #510154 Wed Nov 16 2016 5:33am
