![]() | Home > General > 2.7TDV6 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5053 ![]() ![]() ![]() |
You want to put a french engine in a classic ? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4475 ![]() ![]() ![]() |
With enough time and effort, anything is possible. There was recently an Aston Martin V12 engined RR Classic in one of the LR mags |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Extensive use of a Mexican hacksaw required. |
is that a cutting torch ? |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
I know bell autos who are Spencer's on here put one into a defender and I'm not sure if nene over lander didn't do the same thing so don't see why you couldn't put one in a classic.. 2008 G4 RRSport TDV8 current
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
Presumably you'd need a custom ECU as the engine talks to the transmission and various other systems on the CANBUS. If the ECU just heard silence it's likely to just sit there and refuse to play ball.
I guess the TDV6 is available and value for money.
