Home > Technical > New Brakes all round
dpg123
Hi guys,
I have a 2010 RRS TDV8.
My garage has advised my brakes are worn as follows: Front 60%, Rear 70%). They advised changing all discs and pads (for £1,000!)
In normal driving, what mileage can I expect to eek out of these? We do around 3,000 miles per year so I'm hoping they should last a good while.
I've done a little research online and have found all the parts (4 x discs and sets of pads suitable for the car (front and rear) for £220 deliveres (from Euro Car Parts). However, I've also found these http://www.dls-uk.co.uk/range-rover/range-...-tdv8.html which look super cheap. Should I go for the ECP parts or would the ones from DLS be OK?
Finally, I asked at a competent but non specialist garage close to me and they have quoted £150+VAT for fitting (3 hours labour) if I supply the parts.
What are your thoughts on the above? I don't want to be wasting money for no reason!
Thanks!!
Post #502571 Thu Aug 11 2016 10:05am
First thing I would do is change my garage, 1k for brake pad and disc replacement is a rip-off.
£150.00 just for fitting is reasonable, you can get genuine L/R parts off e-bay cheap enough
Post #502578 Thu Aug 11 2016 11:57am
DrRob
Buy Genuine and buy them from Dan at Duckworths (forum sponsor - search on here and tell him you are a forum member). Significantly cheaper than a main dealer.
I fitted Mintex discs and pads and they warped within a few 100miles. Just my experience and discussed lots over on Disco3 forum Thumbs Up
Pays your money, takes your choice Whistle
Then get a decent independent LR garage (e.g. RR London http://www.rrlondon.co.uk/) to fit them * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #502583 Thu Aug 11 2016 2:57pm
dpg123
Thanks Dr Rob,
RR London were the ones who quoted me £1,000+VAT to supply and fit the brakes. What do you think is a reasonable cost? I've been told it's 3 hours labour (2 hours rear, 1 hour front) + parts.
RR London also quoted me 1 hours labour to fit a new high level third brake light as "it's bonded in". I did my research and it's actually a 10 minute job requiring a screw driver.
Post #502584 Thu Aug 11 2016 3:10pm
DrRob
RR London get good reviews on here and D3 forum but never used myself....did they quote for Genuine parts? My front discs and pads and sensor were sub £300 delivered.
Rovertune in Reading are good
I just got a decent local garage who works on LR vehicles to do mine. They could not get anywhere near Dan's prices either Rolling with laughter
I would get a quote from Dan for all discs and pads and sensors delivered and then ask around for a fitting cost.
Or simply download Bodsy's Brake Bible off Disco 3 forum (a D3 is same car underneath) and DIY Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #502586 Thu Aug 11 2016 3:16pm
Not sure where you did your research, but if you think you can change a high level brake light in 10 minutes and a screw driver I'm afraid you have another thing coming.
Post #502587 Thu Aug 11 2016 3:19pm
Lost for Words
£1000! Thud
When they say the "brakes" are 60%/70% worn, do they mean the discs? If so you should have years left in them at only 3k a year. The mileage you get from discs/pads varies a lot according to what you have, duty cycle and levels of contamination but you could easily have many years left in the discs at that rate. Smile Thumbs Up Visiting from DISCO3.CO.UK
Post #502588 Thu Aug 11 2016 3:26pm
Bodsy
Site Sponsor
60% worn still me as that there is an awful lot of material still left they're trying it on.
For your low mileage, you'll be fine for a good while yet I would say! Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #502589 Thu Aug 11 2016 3:27pm
DrRob
Indeed - take them to at least 95% Rolling with laughter Rolling with laughter
As Ian (Bodsy) says, loads of life left at 3K a year... Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #502591 Thu Aug 11 2016 3:52pm
Pufftmw
Simple maths says that you're doing 10% a year or thereabouts, so at least 2 years left although for that mileage, that's a lot of wear & especially if its in stop/start old London town?
Post #502597 Thu Aug 11 2016 4:34pm
dpg123
Hi, Why do you say that?
Here's the evidence -
spoiler removal:
light removal:
Can you expand on why you think it's any more complicated than this? What's not been shown / made clear?
Thanks
Post #502598 Thu Aug 11 2016 4:44pm
dpg123
It is in London, yes.
Is there any downside to waiting until the sensors tell me I need the brakes changed? Is that not what they're for?
Post #502599 Thu Aug 11 2016 4:46pm
Pufftmw
There's only 2 sensors - NSF and OSR, in theory you could wear out other side quicker I guess. Might happen at the rear if caliper seized maybe - can be prone to it. However, the sensors leave enough margin for error for normal usage.
I wouldn't consider that you had too much to worry about at the moment. Dealers always try and "pre-empt" wear/tear and the rates are stupid (that you have been quoted).
Post #502602 Thu Aug 11 2016 5:51pm
Hi'
Apologise, you are probably right not having a good day really, Sad it is easier if you have a second pair of hands to help support the spoiler though, as easy to mark/scratch the paint on the roof with the three longish mounting studs if trying to juggle it on your own.
Post #502607 Thu Aug 11 2016 6:56pm
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Re: New Brakes all round
Hi Pal I get mine from Euro Car Parts, but I only use Brembo Discs and Pads
hope that helps, very easy to change your self about 30 mins each side, I am in uxbridge I can show you if you like
chuck me an email: mani.gill379@gmail.com
regards
Mani G Thumbs Up
Post #502609 Thu Aug 11 2016 7:05pm
