Home > Faults & Fixes > Rear door lock removal 07
Ste77
Hey guys any links on how to take the rear widow mech out so i can get to the door lock? The daughter thought it would be funny to keep the button pressed in miltiple times whilst i tried opening it Censored the lock works but only just moves the bar.. Cheers Steve
Post #502497 Wed Aug 10 2016 11:24am
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Don't know ow much difference there are between the fron and the rear doors, but i done my front one.
http://www.rrsport.co.uk/forum/topic40499.html
have a read through that and look at the links, it may offer up some help.
Post #502515 Wed Aug 10 2016 2:42pm
Ste77
Cheers mate Thumbs Up
Post #502539 Wed Aug 10 2016 6:53pm
Meiang
Rear Door Actuator Mechanism removal
I replaced the LH rear door lock mechanism on a friends Discovery 3 a couple of years ago. I imagine it is very similar to the RRS. I found it was not necessary to remove the window mechanism or detach it from the window glass pane.
Removing the window regulator bolts and sliding it out of the way gave enough room to remove the lock mechanism (use a piece of masking tape to hold up the window once the regulator bolts are removed).
The trick to replacing the lock mechanism was to remove the outer door handle.
The long outer cover was very easy to remove, the short outer cover less so and you are very likely to break the clips which hold it in place so be prepared to buy a new shorter outer cover.
Once you have removed the outer covers you now need to remove the door handle assembly so that a linkage between the door handle assembly and the door lock can be disconnected. From memory the door handle mechanism was attached to the door by a stud and nut (accessed from inside the door cavity) at one end and the splayed clip at the other end. You need to press out the centre peg of the splayed clip so that the clip can be pulled out from the door sheet metal. This centre peg presence is not immediately obvious and may be quite hard to remove (mine was). I had to use a pin punch and hammer to remove it. I can't remember whether I pushed the pin out from the the inside of the outside).
With the D3 the linkage between door lock and the door handle could not have been disconnected without removing the door handle and there was no access to it.
Once the outer door handle was removed replacing the door lock was easy.
Post #503068 Wed Aug 17 2016 3:46pm
Ste77
Nice one cheers mate im off next week so will give it a go Thumbs Up
Post #503078 Wed Aug 17 2016 5:16pm
