Home > General (L494) > Slow speed chugging/misfiring on 3.0 SDV6 2014 A/B RRS
ali5711
Had 3 occasions in last 2 days at steady 30 and 40 mph in auto and the drive is chugging/misfiring but no alarm fault evident. It is fine at higher speeds and accelerating. Any ideas thanks B4 I trouble LRA?
Post #502170 Thu Aug 04 2016 4:54pm
ali5711
It is not misfiring but auto gear changing up/down and back with steady throttle at 40mph, maybe a control system point with low load?
Post #504596 Mon Sep 05 2016 7:25pm
wilf
See if it does it in "S". MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #504603 Mon Sep 05 2016 8:29pm
ali5711
will do tonight.
Post #504670 Tue Sep 06 2016 5:34pm
PauloAmore
Scotland
Mine did that.
Fix was; remove the Petrol from the diesel tank.
- and replace £9k of stuff. 2022 P440e AB
Post #504677 Tue Sep 06 2016 6:10pm
ali5711
No petrol in thankfully, although I have had suspect fills of diesel quality.
In Sport it does not happen, only in auto under min load and steady speed around 40 mph - must be hunting in the auto gear change point?
Post #504891 Fri Sep 09 2016 6:36am
wilf
Could be that being in Sport stops the 'box going into too high a gear - I find mine tries to do that on occasion, and then I get the driveline vibration/shunting as if I as in manual car in top at 15mph.
Well, OK, maybe not quite that bad, but the same issue at it's root.
So, maybe the next time yours does it, paddle it down a gear and see if it clears? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #504895 Fri Sep 09 2016 8:01am
ali5711
Will do thanks Wilf
Post #504896 Fri Sep 09 2016 9:15am
wilf
Another lead for you. Saw a very similar problem on a jag forum (same engine and gearbox). Problem lay in a faulty brake pedal switch. Worth getting that checked out. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #505514 Thu Sep 15 2016 1:31pm
