Home > Technical > Rear Propshaft Centre Bearing
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi Lads
Working through servicing on the Sport, Managed to replace Fan Belt without removing Fan (more due to the fact that I couldn't get the fan off).
And to my surprise this appears to have cured the Tinkling noise I had on start-up Confused
Went under to remove the cover to replace the Fuel Filter and have noticed that the Centre Bearing/Rubber mount on my rear Propshaft is Goosed. What's the thought's on replacing the Centre Bearing/Rubber Mount or should I replace the full Propshaft.
Is it still ok to use the car when the Bearing/rubber mount is like this. Need to use car over weekend and look to replace Bearing /Rubber mount or Propshaft next week.
Cheers Jock. Thumbs Up
Post #501794 Thu Jul 28 2016 9:26am
The general view over on Disco is that replacing the full prop shaft is the best option. The bearing can be done but... 2012 SDV6 - it's missing a couple of cylinders
Post #501801 Thu Jul 28 2016 2:02pm
Jock 77
Re Propshaft
Cheers RRSTDV8
Found an article in LR Addict showing a Centre mount replacement ,Not sure about the Peening of the joint and spline cover if it would be successful. Also quicker to replace with a new one.
Island 4x4 have a GKN Prop for £190 +vat ,Can anyone recommend anywhere else with a better price.
Cheers Jock Thumbs Up
Post #501804 Thu Jul 28 2016 3:45pm
Jock 77
Re Propshaft Centre Bearing
Hi Lads
Removed the Propshaft today and the rear Hardy Spicer also notchy ,So have ordered a New propshaft .
Just an afterthought is it okay to re-use the bolts with Loctite threadlock or should these also be renewed.
Post #501870 Fri Jul 29 2016 10:07pm
Manual says discard the (4) bolts from the diff end but reuse the (6) bolts from the transfer box end. 2012 SDV6 - it's missing a couple of cylinders
Post #501877 Sat Jul 30 2016 12:38am
Jock 77
Cheers RRSTDV8
Will order up the 4 new bolts for the Diff end.
Cheers Bud Thumbs Up
Post #501878 Sat Jul 30 2016 12:55am
