Home > In Car Electronics > Cigarette Lighter Centre Console +Ve Feed
Pufftmw
Hi guys
Installing a new HU to my 2007 HSE and part of that install is to run a wire to a +ve feed, preferably cigarette lighter or fuse board.
Without having to take all the complete console around the gear stick to pieces, there happens to be a handy little inspection hole at the bottom of the cup-holder. Opening that up shows the wires that run from the cigarette lighter to the wiring loom. I've confirmed this by the old pull test as I can just get my hand down to touch the bottom of the socket and tug on the wire tugs the wire in the inspection hole.
I have black, red/black and green/white. G/w is thicker than the r/bl, so I'm guessing that that is the +ve to the lighter socket?
If someone could confirm, then I can get a scotch block onto it relatively easily and without having to take the console to pieces!
TIA
(yes I know scotch blocks are the spawn of the devil Twisted Evil & my responsibility)
Post #501632 Mon Jul 25 2016 7:02pm
Pufftmw
Post #501633 Mon Jul 25 2016 7:04pm
Thin red is probably illumination.
Green is normally ignition.
Well done. That's a nice easy way to get to the wires.
Post #501643 Mon Jul 25 2016 9:12pm
Pufftmw
Hmm
Looked at the rear 12v and its got 2 thin wires only, so now wondering if g/w is the light as its thicker and the other 2 are the same.
Doh!
Post #501652 Mon Jul 25 2016 10:04pm
I've checked the diagrams and its green/white
Post #501655 Mon Jul 25 2016 10:55pm
Pufftmw
Thanks Andy, I'll jump onto that one then Very Happy
(Let you know if its not LOL!)
Post #501682 Tue Jul 26 2016 9:27am
Pufftmw
Hi Andy
It was g/white and is now a good ignition feed for the new HU. It was a bit fiddly to do but better than taking centre console to bits.
Post #501739 Tue Jul 26 2016 10:45pm
