Home > Maintenance & Modifications > Replacing front proximity sensors
Black Bess
One of my front sensors has started to breakdown, causing the warning sound to trigger inside the car for no reason.
I have a replacement unit, but have not tackled this job before. In the hope that you can save me some time, does any one know if you have to remove the whole front bumper to gain access, or is there and easier way?
Apologies if this has been covered before, but I could not find it.
Thanks
Adam..
Post #501263 Wed Jul 20 2016 10:58am
If its an outer one, you could probably jack it up, take the wheel arch liner out and replace.
Personally its just easier to remove the bumper without having to jack it up
Post #501269 Wed Jul 20 2016 12:23pm
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
I recently replaced the front drivers side corner one, only needed to remove a few of the screws under neath and in the wheel arch to get enough access to replace it.
Post #501452 Fri Jul 22 2016 2:34pm
Black Bess
Thank you both. I think my duff one is the inner one, next to the number plate. I will have to have a look at the job and report back.
Adam..
Post #501611 Mon Jul 25 2016 1:43pm
remove 4 tor-ox bolts under the bumper
remove a screw in the wheel arch
remove 2 screws each side (at ther bottom) holding the wheel arch to bumper
Remove grill
Remove headlights
disconnect connectors under headlight.
remove 8mm bolts along the top of the bumper
Remove bumper onto cardboard. Note headlamp washer pipe is still connected.
Post #501642 Mon Jul 25 2016 9:10pm
Black Bess
Thank you. That is great. I will have a go at it when I get time.
Adam..
Post #501752 Wed Jul 27 2016 9:19am
