Home > Maintenance & Modifications > 2010-2013 SVR Style Bumper
Just noticed these on Flea-Bay thought they look quite nice, Hawke so think quality should be good.
Post #500894 Fri Jul 15 2016 10:33am
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Looks alright Col, have you fitted the GTS bodykit yet? Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #500895 Fri Jul 15 2016 11:02am
Hi Tony,
Got the all the Rear Bumper, Exhaust Tips etc. fitted, Front Bumper etc. in the Body shop being Sprayed at the minute so hopefully all done for next week.
Post #500897 Fri Jul 15 2016 11:18am
tonywolf
Nice mate, will look forward to seeing the finished article :thumbs: Once I get back home (later in the year) I will probably complete the 5.0 sc upgrade for the rear discs and callipers. Also fancy doing the newer wing mirror upgrade, its quite pricy isn't it if you want the singing all dancing mirrors? Best Regards
Tony
Post #500901 Fri Jul 15 2016 11:28am
Yeah do like the new Mirrors look the part, but works out about 1k if you buy all new parts from L/R as everything is separate, they don't do complete mirrors. The only part you can use from old mirrors is the motor and they are about £50 from L/R, did manage to get a pair of brand new housing of flea-bay for £400.00 and a pair of the top caps all ready sprayed Santorini for £35.00 so that was a good start.
I'll pm you some parts numbers later if any use so you could keep a eye out.
Rear brakes are not Brembos they are TWR but are 365mm and I think the 3.0Ltr is 360mm, did replace Discs and Pads on mine recently managed to get genuine parts from Main Dealer on Flea-bay for £140.00 the lot, worked out about half price also got complete set of H/brake Shoes/Spring etc. O/S and R/S genuine parts for something ridiculous like £15.00 so couldn't no at that price.
Post #500905 Fri Jul 15 2016 11:54am
tonywolf
Thanks :thumbs: When I did the fronts, I purchased the splash guards as well, but I didn't need to as my originals were the same size as the 5.0sc ones, so Im hoping that the rear splash guards will be the correct size. I will probably need new calliper brackets and use my current callipers with 365m discs. Best Regards
Tony
Post #500906 Fri Jul 15 2016 12:05pm
Hi Mate,
Not certain but I think you might find the original caliper will not fit the S/C caliper carrier so you might need the caliper as well, will see if I can get a couple of pictures.
Post #500910 Fri Jul 15 2016 12:30pm
tonywolf
Thanks, something to look forward to on my return
Thumbs Up Best Regards
Tony
Post #500911 Fri Jul 15 2016 12:37pm
