Home > Maintenance & Modifications > Brake problem
Black Bess
Brake problem
Hi,
I have a distressing problem developing with the brakes on my 2005 2.7 V6 diesel.
Under most circumstances the brakes are fine, but if I have to make a long, firm stop, say from 60 mph to standstill, the brake pedal sometimes goes solid and I am unable to apply extra brake pressure than that already applied.
It feels as though the vacuum to the servo is all used up and that I no longer have servo assistance.
Before I look into it, I am hoping somebody here can give me the benefit of their experience.
Might it be a faulty servo, or vacuum pump? Where is the vacuum pump?
Thanks for your help
Adam..
Post #499595 Mon Jun 27 2016 9:29am
There is a known issue with oil getting in to the brake servo. Should have been done as a recall so might be worth talking to LR about it. 2012 SDV6 - it's missing a couple of cylinders
Post #499602 Mon Jun 27 2016 10:05am
Black Bess
Ah yes, I wondered about that. I will investigate the servo and see what is going on, I think. It does feel as though vacuum is being lost after a long brake application. On the next application, it has come right back again.
Thanks very much.
Adam..
Post #499715 Tue Jun 28 2016 9:13am
Bodsy
Site Sponsor
This is def brake booster problem.
You can get a supercharged brake booster for about £40, similar price for the master cylinder. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #499717 Tue Jun 28 2016 9:17am
Black Bess
Thank you Bodsy, just the advice I was looking for. Very Happy Very Happy
Are the servos and master cylinders available from factors, or are they agent only?
Thanks
Adam..
Post #499718 Tue Jun 28 2016 9:20am
Bodsy
Site Sponsor
Ebay is ere I sourced mine from. One came from a main LR dealer and the other from a LR parts supplier. All genuine. Haven't really looked for aftermarket ones as at those prices, it was a bargain. Main dealer normal prices are significantly higher! Bodsys Brake Bible
See it HERE
Post #499723 Tue Jun 28 2016 9:25am
Bodsy
Site Sponsor
SJJ500080 for the S/C booster
SJJ500010 which is a Disco3/RRS std one.
The master cylinder was ebay item number eBay Item No. 191554902817 (not checked if still available) Bodsys Brake Bible
See it HERE
Post #499724 Tue Jun 28 2016 9:31am
Black Bess
Brilliant, Thank you.
Adam..t
Post #499921 Thu Jun 30 2016 4:29pm
Black Bess
I removed the master cylinder last night to investigate this problem. The servo was half full of engine oil!!
So, I have removed the oil, but obviously need to address the source as well as renewing the servo. Is it likely to be a worn vacuum pump, or is there another reason for the oil to be coming through?
Because the servo functions ok, but loses assistance on a long brake application, I am suspicious that the vacuum pump may be losing efficiency and unable to keep up with demand under these conditions. Is that likely?
After 120,000 miles I think it is not unreasonable to replace both master cylinder and servo and potentially the vacuum pump too, but I am hoping to avoid chasing the problem in circles.
Your collective wisdom is very much appreciated Smile Smile
Thanks
Adam..
Post #501754 Wed Jul 27 2016 9:27am
HemoRRS
May be of help
Quote:
R/2009/073
Exact Model: Discovery 3 TDV6 & Range Rover Sport TDV6
Description: POSSIBLE REDUCTION IN BRAKING ASSISTANCE
VIN: SALLAAA136A367110 to SALLAAA149A513325
Build Date: 31 October 2005 to 26 June 2009
Numbers: 56142
Defect: It has been identified that, some vehicles may experience a reduction in braking performance leading to increased stopping distance, due to the possibility of oil entering the brake booster or the brake vacuum pump non-return valve sticking in the closed position after cold start.
Action: All recalled vehicles will be fitted with a modified brake vacuum pipe along with a revised design non-return valve in the secondary port of the vacuum pump.
Launch Date: 28 September 2009
Post #501756 Wed Jul 27 2016 9:53am
Black Bess
Thank you. Actually mine pre-dates that recall, being registered in September 2005, but I think I will speak to the dealer about it and see what they say.
Post #501761 Wed Jul 27 2016 11:17am
Paddi
Given JLR's generally er..... 'relaxed' attitude to things like record keeping, quality control and documentation accuracy I'd say there is a good chance that your vehicle should have had the recall rectification work.
Push for it to be fixed FOC 2008 MY Java Black TDV8 HSE
Post #501766 Wed Jul 27 2016 2:23pm
Black Bess
Well I contacted my local dealer and it appears that a recall does affect my vehicle, so I have booked it in and will see what they make of it. The recall is on loss of vacuum assistance and relates to the vacuum pump. So I will be highly delighted if they change it for me for nothing. Cool
Will report back after it has been in.
Adam..
Post #501792 Thu Jul 28 2016 9:04am
As you too have found out;
I found another TSB, which adjusts the date to the start of production of the RRS
Post #501797 Thu Jul 28 2016 12:51pm
kozzone
Finland 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Adam..
Have you got any update on this? Im having the same exact symptoms on my 07'. I contacted a LR dealer and they told me this recall has already been done to my car years ago.
So could you advice me what parts should I get to fix this problem Smile Or what did they change on your car.
-Toni
EDIT: Sorry I misread when you posted. So I'll be waiting silently here in the corner for your update Smile
EDIT2: Also you can hear weird noise when I press brake pedal for a while even when stationary. And this all happens when I press brake for a longer time. Not when its applied for a short period of time.
Post #501847 Fri Jul 29 2016 12:41pm
