![]() | Home > Maintenance & Modifications > Carbon Clean |
Doesn't diesel fuel also partially lubricate the engine? I wonder how these guys maintain the lubrication levels for those 30 minutes of running or is the hydrogen injected instead of "air". 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
The words 'snake' and 'oil' spring to mind. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9137 ![]() ![]() ![]() |
Add hydrogen to the intake? So they burn the hydrogen in the engine? Burning hydrogen just makes water (steam) so presumably they are using the steam to clean the engine. As hydrogen is fairly expensive and they will want to make a profit on their time too, I would guess they don't add much hydrogen. So not much steam is produced either. 2012 SDV6 - it's missing a couple of cylinders
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
Found a bit more out, http://www.enginecarbonclean.com/technology.php
Disco Mikey had his done to see if it's a load of |
They electrolyse water to get hydrogen (and oxygen) and then put the hydrogen in to the engine. Burning it is supposed to "react with carbon deposits" and break them down. I'm doubtful about it, I must say. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
That was a Terraclean. Still trying to arrange something with the Hydrogen (if only to see if it helps with glow plug removal ) ![]() |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 148 ![]() ![]() |
I guess if you subject carbon to sufficiently high temperatures, it will oxidise and the result will be carbon dioxide. |
Sounds like it's pretty new kid on the block, the tech guy says he had at least 3 cars a week come in with over boost issues, after a clean the faults clear. He had printed evidence of the exhaust gas stats which showed a before and after, tell the truth I was 99% signed up but then my scepticism stepped up.
