Home > General (L494) > HELP: Where is the battery...?
JanRRS
United Kingdom 2013 Range Rover Sport SDV6 HSE Stornoway Grey
might sound a weird question ... But I can't find the battery, or the main battery in case of multiple batteries! Where is the battery?
Can't find it in the bonnet, nor under the spare wheel ... Which should be the obvious first places to look at. Nor can I find it any references to the battery on the manual, or online ...
My RRS L494 is the latest MY 2016, built in May 2016, delivered last week, and I want to hardwire the battery in order to get one of the cigar lighters live, so that I can just plug in the Ctek battery charger/maintainer, or just get my devices charges even if the car is turned on ...
Or, alternatively, does anyone know if there is already a live cigar lighter?
Thank you
Post #499451 Sat Jun 25 2016 9:41am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
Far easier to connect the CTEK to the two power terminals on the offside of the engine.
Post #499453 Sat Jun 25 2016 10:00am
JanRRS
Thanks Phil. Where exactly are those terminals? Do you use the comfort connection cable, or just the clamps?
ps. but where is the battery ... ?
Post #499456 Sat Jun 25 2016 10:08am
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
See my reply in this thread.
http://www.rrsport.co.uk/forum/topic43133-15.html
Regards,
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #499457 Sat Jun 25 2016 10:12am
JanRRS
Thanks Jock.
Jan
ps. have checked my profile, and yes you are right it does not say L494, but it only allows me to choose the RRS MY 2013 ... Can't figure out how to get that changed.
Post #499460 Sat Jun 25 2016 10:29am
JOCK55
The only way to change that is to do one or all of the following:
Use the sister site http://www.RRSPORT2.com website (where us L494 owners are supposed to reside)! Unfortunately this is under utilised. Maybe a handful of posts per month!
Complain to Martin or one of the mods on this site.
Best of luck with either or both remedies!
Regards,
Post #499462 Sat Jun 25 2016 10:35am
JanRRS
Laughing Laughing Laughing
Thanks
Post #499463 Sat Jun 25 2016 10:37am
Tim in Scotland
I am the under used moderator of RRS2 forums (and the BabyRR/ Evoque forum) and you cannot even select a model/ colour avatar in the profile settings there so just use what you have like I do here................... Best thing to do is to take a low res photo of your car and in your profile here upload it as an avatar, has to be low res as the file size is restricted.
FYI the Land Rover branded Ctek battery conditioner that I had on my Evoques and is similar to the RRS2 version, had a remote socket hidden behind the front grille that I could plug a remote cable from the charger into when I wanted to use it so I didn't risk chopping the cable in the bonnet slam or tailgate seal. I used to use a £10 Maplin solar panel trickle charger to keep my car batteries topped up but since 2011 LR has not seen fit to leave a socket live when the ignition is in the off position. I suspect because there have been so many battery drain problems with all their cars it is so you cannot flatten the battery by leaving a charger accidentally plugged in when the car isn't in use. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #499464 Sat Jun 25 2016 11:42am
JanRRS
Thank you Tim.
Tried to upload a pic ... But even the smallest and lowest resolution pic does not upload. Maybe it's my iPh. But I'll leave just as it is ...
Post #499467 Sat Jun 25 2016 12:58pm
philmw
The advent of the power management module, which turns things off when not required, precludes the use of fag-lighter sockets and stuff. I'm not sure you can charge the main battery by connecting the charger to the small battery in the boot as I believe there is a switch that isolates the two when the charge on the small battery is full.
I use the croc clips on the terminals (the positive is under a rectangular cover with a '+' marked on, the chassis is a post just in front of this.
Please excuse the dirty engine bay - Goodwood FoS yesterday (11.5 hours travel for 3 hours of fun. Thanks to JLR & SVO though for their excellent hospitality Thumbs Up ).
Post #499477 Sat Jun 25 2016 3:24pm
JanRRS
Thanks Phil. Thumbs Up
All sorted. By the way, I placed it exactly as yours, without seeing your pic: the bonnet closes easily and all is safe.
BTW do you know if those terminals connect directly to the battery, or do they go through the whole circuit, with some power losses on the way to the battery?
Post #499478 Sat Jun 25 2016 3:33pm
philmw
I don't know, but I imagine they go direct to the main battery (which may be hidden under the fuse box on the nearside bulkhead).
Post #499479 Sat Jun 25 2016 3:37pm
JanRRS
Thanks Phil. I think the main battery is just under the spare wheel in the trunk ... Am not 100% sure but have noticed some wiring there in the back under the wheel. Don't think there is sufficient space near the engine for an AGM Battery. And think that it is now common sense to keep the battery away from the heated zone of the engine ... My BMW X6 and previous X5 had it in the trunk.
Post #499487 Sat Jun 25 2016 5:03pm
philmw
Yes, you're correct. Under the floor where the spare wheel would be if you have one.
Post #499488 Sat Jun 25 2016 5:14pm
JanRRS
This video might be very useful:
Post #499579 Sun Jun 26 2016 10:05pm
