Home > Maintenance & Modifications > Brembo Brake Upgrade
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
This may have been covered before, but is there any order for bleeding the front brakes once the Brembo callipers/Discs have been fitted, i.e. NS/OS or OS/NS? Thanks guys Thumbs Up Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #498685 Wed Jun 15 2016 9:15am
There is a procedure in the Workshop Manual but basically start Furthest from Master Cylinder N/S/R, O/S/R, N/S/F, O/S/F.
Nothing really complicated.
Post #498687 Wed Jun 15 2016 9:31am
tonywolf
Thanks Col, rear callipers to be bled even though I'm not touching the rears? As you are aware there are 2x bleed nipples on the Brembo callipers, can I presume I only need to bleed from one of them per calliper i.e. the outers? Best Regards
Tony
Post #498688 Wed Jun 15 2016 9:55am
Hi Tony,
Found this bit, obviously Brembos are the High Performance Brakes.
14. WARNING: High performance front brake calipers have two
bleed points. The inner bleed point must be bled before the outer
bleed point. Braking efficiency may be seriously impaired if an
incorrect bleed sequence is used.
You probably don't really need to bleed rears, personally I would do it as ideal opportunity for fluid change which can't do any harm for the sake extra few quid for fluid.
Post #498695 Wed Jun 15 2016 10:46am
tonywolf
My friend you are a font of knowledge, many thanks Thumbs Up Best Regards
Tony
Post #498697 Wed Jun 15 2016 10:58am
