Home > Technical > wrong fuel in
Hamner
Wales
wrong fuel in
hi all , can someone help me with a problem for a RRS TDV6 2006 plate. Petrol was put in instead of diesel. A local garage got it running again - but it is now giving out white smoke, running really rough and the garage has said that it is showing an injector fault. Has anyone had a similar problem and how did they rectify it. Many thanks.
Post #498301 Thu Jun 09 2016 12:49pm
muddywheels
Milk Float Man
Never done this myself but some threads here might help
http://www.rrsport.co.uk/forum/search.php?...rch_time=0
I haven't time to read them but remember it causes problems with seals if you misfuel either diesel or petrol but can't remember which sorry Confused
I'm sure someone who knows will answer soon Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #498303 Thu Jun 09 2016 12:56pm
Tim in Scotland
The seal problem is with diesels that are misfuelled with petrol, the benzine might dissolve them...........
Did you run the engine at all? If no petrol has gone into the fuel pump in the tank and every single drop was drained out them you might get away with it, but if the engine was started, even for only seconds then you have a problem. After a misfuel it essential not to even start the engine. The report of white smoke and lumpy running suggests though that petrol has got into the high pressure fuel system and to the engine 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #498305 Thu Jun 09 2016 1:15pm
Johnski
LR Assist or most of all the major breakdown companies cover this, some car insurance companies offer it at a extra premium.
The main thing to remember is DON'T/NEVER start your vehicle if mis-fuelled, as that will end up costing you lots. Crying or Very sad
Most forecourts have a number to ring for draining down system etc, as long as not started, then you go on your way.
I know my RRS and I thought most had a insert in filler tube , to stop this happening? Embarassed John
Post #498307 Thu Jun 09 2016 1:32pm
Tim in Scotland
LR only started fitting misfuelling devices with the introduction of the TDv8's in 2007MY unfortunately. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #498311 Thu Jun 09 2016 2:42pm
gogsy1956
I also thought all Rrs had the miscued device in the filler,,, tried mine out a couple of weeks ago( by accident), managed to get 26p worth of petrol in before it shut off. Good job the tank was empty,, just tanked it to the top after resetting the misfuel device. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #498313 Thu Jun 09 2016 2:59pm
Hamner
Wales
hi guys thanks for the replies , yes the engine was run for a short time Big Cry
Post #498323 Thu Jun 09 2016 6:04pm
Not sure my MY08 TDV8 has the misfuel device...must admit to never having tried it though! 2012 SDV6 - it's missing a couple of cylinders
Post #498329 Thu Jun 09 2016 6:58pm
Olly-ibiza
The biggest problem with misfueling is the high pressure fuel pump, to achieve the insane high pressure required for a common rail diesel engine the tolerances inside the pump are very small, the pump uses the diesel as a lubricant, if you have petrol in there that has no lubricating properties it basically wears the faces in the pump and leaves you with low fuel pressure spiteful Range Rover Sport tdv8
Post #498335 Thu Jun 09 2016 7:30pm
Tim in Scotland
My 2007MY did, it was a yellow plastic device that was in one of the cutouts in the polystyrene kit holder above the spare wheel. It was simple to use........... Push down the filler hole and reset the flap! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #498341 Thu Jun 09 2016 8:22pm
Johnski
You can purchase them, not sure if they will fit all the earlier models though?
I also have large warning on inside of filler cap, you can't miss it when putting your cap on the holder before filling.
I couldn't even get the petrol pump nozzle in (after first purchase and switching fuels) let alone get any fuel into tank, according to handbook it shouldn't let any wrong fuel in. Wink
It can be a very costly error misfueling, with fuel pump, replacement seals etc requiring replacement, so please take care out there. Thumbs Up John
Post #498343 Thu Jun 09 2016 9:10pm
Hamner
Wales
wrong fuel in
hi all, it was,nt me who missfueled it was the MRS by the way Whistle
Post #498390 Fri Jun 10 2016 4:39pm
muddywheels
Milk Float Man
Oh yes - I would love a get out of jail card like that - I could use it for years Mr. Green Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #498393 Fri Jun 10 2016 5:18pm
I checked today when filling up. The neck has no misfuel device in it. Odd. 2012 SDV6 - it's missing a couple of cylinders
Post #498477 Sat Jun 11 2016 10:08pm
