![]() | Home > Maintenance & Modifications > Aftermarket rear upgrade led lights |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
I assume the logic to the other lights being out could be better illumination ? How ever it would be good to ask why they have decided to have the other lights out in reverse. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
It wouldn't fail an MOT because reverse lights arn't part of the test..
Welcome to the forum - Do you have a link to the lights ? You may find it useful to update your profile underneath your username this will help when advising on certain issues |
magbeto Member Since: 01 Jun 2016 Location: manchester Posts: 4 ![]() ![]() ![]() |
Thanks for the quick responce, my MOT guy says that aswell ,reversing lights are not part of the MOT, but when activated they do affect the brake/rear/indicators etc etc so as none of them work it would be a fail ???. The lights themselves are fittted with resistors so no speeded up dash lights or anything everything else works fine together it is only when reverse selected that is the problem anyone else had this and did anyone else sort it and how ? |
Down&Dirty Member Since: 31 Dec 2015 Location: Somewhere out back Posts: 92 ![]() ![]() |
Could you not remove the reverse light power from the plug that goes to the lights?
Maybe, i don't know and i'm not very good at that electrickery stuff |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
send um back |
Think that that is the best option, if they don't fail an MOT ?? then surely they must fail under construction and use ? Thing is though you would never notice if you tested them individually it was only when i was reversing on a car park at night in front of a shop window that i noticed, i wonder how many are running around like this |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
The lights I got for mine didn't have reverse lights in them, which I don't mind as the IR on the reversing camera is better when its dark spiteful Range Rover Sport tdv8 |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I bought aftermarket LED rear clusters and they work perfectly, I had to fit my own reverse and fog bulbs but everything else is LED.
