Home > Maintenance & Modifications > Bonnet lettering
Ross_F
Bonnet lettering
Hi all - quick question. Has anyone had any bother applying bonnet lettering to their RRS? Had a full machine polish done and then the UV damaged titanium ones replaced with satin black that I'd bought from the LR Centre.
Problem is, they've gone on all wonky, so I've had them taken off.
Any thoughts/suggestions appreciated. The chaps that did the polish insist they used the spacing and tempting but it really, really doesn't look right and they blamed it on them not being OEM.
Post #497073 Thu May 26 2016 2:43pm
TheWojtek
BS.
I've replaced mine. They came with a template for each word separately and precise description of the distance from the lower bonnet edge to baseline and bonnet creases to left and right "R". Your letters are OEM sized and should be perfect but look like they were installed by a drunk in a dark garage. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #497074 Thu May 26 2016 3:05pm
PEACHY
That is dismal - there is so many different templates - the version it is for is embossed on the template card - a few forum members have purchased the off fleabay but when they have arrived they are for another Range Rover model Rolling Eyes
Think you may need to start again - Rolling Eyes 16MY Estoril Blue SVR.............
Post #497075 Thu May 26 2016 3:05pm
Ross_F
Thanks guys - yeah that's what I thought. I was going to do it myself, but like I said it had a full machine polish so I figured the bodywork guy would be a dap hand.
I'll have a look at the ones from PowerfulUK as I'd like to replace the interior bulbs with LEDs anyway so can order in one go.
Post #497077 Thu May 26 2016 3:08pm
Socast
If they've twisted like that after the bonnet was polished they I would suggest that the surface wasnt prepared properly when the letters were applied.
It's actually best to apply the letters (or any adhesive) when the surfaces are warm, this allows for a much better bond. The trick is maintaining the heat for a few hours while the glue sets, so either get some heaters in your garage or if you don't have a garage get friendly with someone who does haha.
Post #497078 Thu May 26 2016 3:13pm
Ross_F
Appreciate it. Cheers.
Post #497079 Thu May 26 2016 3:31pm
Tyrefitter
I got mine off flea bay & they are fine,,I got a friend to fit them who does signs & letters vehicles.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #497097 Thu May 26 2016 7:47pm
Jaggs
Wow that's shocking. I had mine replaced by the guys who detailed the car no problems, they took photos and measurements of old ones before removing and new ones spot on so it can be done, they were on a template for each word Nanocom Evo
Post #497102 Thu May 26 2016 8:23pm
Russben
That looks like they were possibly designed for the tailgate or a different model Rangey? There's a different curve to them as the two separate words Range & Rover seem to individually curve downwards. The fitters may have used the supplied template, but it wasn't the correct one for the front of a Sport.
You might want to check with the suppliers they supplied the correct ones. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #497129 Fri May 27 2016 3:21pm
Ross_F
Thanks Andy, Jaggs & Russben Very Happy
Post #497135 Fri May 27 2016 4:59pm
ilard
Aside from the being on the wonk, the gap between the two words is missing. So it's all very, very wrong! Good luck with getting it corrected. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #497155 Fri May 27 2016 8:29pm
Have to agree with Russben, reckon they used a Tailgate Template on the Bonnet.
Post #497157 Fri May 27 2016 8:34pm
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Same here. Found out the difference while ordering.
Tail gate needs straight template as the bonnet needs a curved one.
Thumbs Up SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #497179 Fri May 27 2016 11:14pm
